Ricoh Aficio MP 161 Drivers
  • glenbennett
    • May 2015
    • 68
    [Misc] Ricoh Aficio MP 161 Drivers
    Hello
    Today I tried to install A Aficio MP 161 , However the client had windows XP and I could not find drivers... What drivers might I look for that will act as a replacement for XP drivers.. What drivers are compatible?
    Also when I did hook up the machine with a USB it only found PS drivers I don't know if thats ok.. when I hit test page it started to spit out about 30 pages of"Pages of Fonts and DOS and Gibberish... Is there a setting I need to go into to this problem and also I remember it kept on flashing on LCD screen will not print in DHCP mode can I go into settings and change this? What is Admin password so that I may get into network settings of this machine?
    Thank You
    Glen
    Thank You,
    Glen Bennett
    • 37532
    Re: Ricoh Aficio MP 161 Drivers
    Try the Vista drivers. Ricoh discontinued driver support for XP a few months ago.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Sounds like the machine does not have the PostScript option (which you have to buy.).
      You will need PCL or possibly RPCS drivers. You can get output with the HP LaserJet 5 driver (comes with Windows), but you won't be able to use any extended functionality.
      Also, tell the customer they need to get rid of XP. Nobody supports it, and it's a security risk, as there are no more updates available for it. Supporting it is NOT your problem; they will need to understand that it's on them if the machine will not do what they want it to, let alone reliably.
