Serious problems with MP 2501
  • black
    • Aug 2015
    • 6
    Good morning.
    I have serious problems fixing a Ricoh mp2501.
    This machine got broken (for the second time in 14k prints!) the black plastic frame containing the main gear train.
    After replacing that, machine starts normally, but if i close the right door, sc144, sc992 (sc620-1 engine) and "set photoconductor properly " occurs.
    Could it be something placed wrong? Bicu and power pack replaced already..
    Many thanks in advance!
  • Polarbear
    • Feb 2012
    • 1070
    Re: Serious problems with MP 2501
    I would check that the charge, bias and transfer cables were connected to the right terminals for starters and that all other connectors are in the correct sockets on the bicu and that they are seated correctly.
    Press the GREEN button!!
    • rosspt
      • Mar 2012
      • 92
      I'm thinking the same thing. Check all wire harnesses and connections, you can use the point to point manual if needed. I would also look for ground connections and possible shorts.
      • bob marley
        • Jan 2012
        • 1339
        yes
        Live for yourself and you will live in vain. Live for others, and you will live again
        • black
          • Aug 2015
          • 6
          Ok.
          Problem Solved connecting cables to right connectors.
          The frame of the main gears failed twice in 14000 prints because the main chassis (the plastic frame of the machine) it's broken. Basically , the gears don't fit right and their housing end up breaking very soon.
          Thank you all for your help!
          • Danwood007
            • Feb 2013
            • 36
            Originally posted by black
            Good morning.
            Hello. Please help. I have this exact Sc144, sc992, set photo conductor properly fault. What exactly fixed it? Not entirely sure I understand the end message.
              • 37365
              Start a new thread grave robber. This one is 5 years old, dead and was buried rather deep in the history.
                • 16311
                • Danwood007
                  • Feb 2013
                  • 36
                  • black
                    • Aug 2015
                    • 6
                    it was just two connectors inverted on bicu
                    ahahh lol slimslob
                    • Danwood007
                      • Feb 2013
                      • 36
                      ahahh lol slimslob
                      Well it can't be that for me. The boards have never been removed before
