Setting MP 301 Baud Rate
  • sushilover111
    • Jul 2025
    Hi,
    I am having trouble with my Aficio MP 301 fax machine since we switched to VoIP. I want to set the baud rate to 9600. From searching the forum I know I need to set:
    SP 1-105-006 ( G3 SW 05 ) Bit 0 and 1 to 0 / Bit 2 to 1 / Bit 3 to 0
    SP 1-105-007 ( G3 SW 06 ) Bit 0 and 1 to 0 / Bit 2 to 1 / Bit 3 to 0
    However I don't know how to get the machine into that programming mode. I am not too familiar with fax machines, so I am looking for the steps to do it (saying "same as any other machine except..." probably won't help me!)
    Thanks in advance -
    Rob.
    • 37489
    Re: Setting MP 301 Baud Rate
    If you do not know how to get into the Service Program (SP) then you are not trained on any Ricoh equipment. The sequence is the same as for the 03 color models. It is not in the service manual (you have to ask your supervisor) but if I remember correctly it is given in the online service training at Ricoh Learning Institute. You can also call your regional support individual.
    • sushilover111
      Through a lot of Google searching and experimentation I figured it out - I am posting here in hopes that it helps others. This definitely worked on a Ricoh Aficio MP 171 and I am assuming it will work on most Aficio MP models.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Not sure on the 301, but the key sequence has been changed on the 03 and newer models, like SlimSlob said.
        • Iowatech
          Not a service manager
          • 3930
          Also, it would be in your best interests to confirm that the VOIP network is entirely standards based.
          If that's not the case, you will find no joy in anything we could tell you.
          Good luck.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            VOIP is a colossal PITA for an MFP to start with.
            Not very predictable.
            I had an account some years back with an MP1515 and an MPC 2550 (I think).
            Both machines sent OK, but receiving was another story.
            The 1515 always worked, but the C2550 worked maybe 20% of the time.
            We changed ALL the recommended settings; no joy.
            We even switched the machines around. No change there, either. We swapped the C2550 with a new one, and it made no difference.
            Eventually the customer did get some new telephony equipment, which did help a bit, although not much.
              • 37489
              I guess I have been lucky so far. With every one of my customers who has VOIP service, they merely notified the VOIP provider which line(s) would be used for facsimile and the VOIP provider took care of all configuration changes on their equipment to allow the line to appears to be a standard metallic phone line to a fax machine.
              • Debs1964
                • Oct 2010
                • 1693
                I don't think it's changed on the MP301
                There are 10 types of people in this world, those who understand binary maths and those who don't
