Ricoh MPC2000
  • PCTECHMECHANIC
    • Jun 2015
    • 14
    Ricoh MPC2000
    When trying to make a black & white copy, it will copy what I place in the tray however there is a 1/2" void down the middle. I thought maybe it might be the black toner so I replaced it with new one. Still doing the same thing. Any help would be greatly appreciated and thank you in advance!
    • 37542
    Re: Ricoh MPC2000
    Sounds to me like center erase is set. From the copy function screen, press the Edit button and turn off center erase. Reprogram the defaults. If it is not there, User Tools - Copier Document Server Settings - Edit - Erase Center Width
    • NeoMatrix
      Senior Tech.
      • 3513
      Re: Ricoh MPC2000
      Are you reducing or enlarging ?
      Are you using book-mode or two page separation mode ?
      What paper sizes are in the paper trays or hand feed through the bypass tray ?
      Can you post a sample image to the forum?
      • davel
        • Oct 2011
        • 1107
        Re: Ricoh MPC2000
        Does it do it on colour, internal print or only on copy.
        • jfbar1
          • Oct 2008
          • 53
          Re: Ricoh MPC2000
          Disassemble black PCU, clean the doctor blade with a thin mylar, or I used to use a business card.
          • Zaxxon
            • 608
            Re: Ricoh MPC2000
            Toner spill on lsu glass.
            Please start you post with brand, model, problem.
            • PCTECHMECHANIC
              • Jun 2015
              • 14
              Re: Ricoh MPC2000
              I attached a copy I tried to make and you'll see in the middle what its doing.
              Thank you again for any help or advise given
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                Re: Ricoh MPC2000
                I would say either an void area on the black dev roller or toner has spilled onto the laser glass for black.
                Check the laser glass first as it's the quickest and easiest to clean, you can use the blue cleaning rod tool inside the front door.
                Failing that remove the dev unit from the black PCU and check for an void area in the centre of the dev roller, rotate the dev roller backwards 4 or 5 times then forward again until you get dev roller to fully coat without any voids.
                • sandmanmac
                  • 3981
                  Re: Ricoh MPC2000
                  Right...and there are about 5 suggestions already.
                  If swapping in a new toner cartridge was your theory to resolve this problem...... then you need a tech.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Re: Ricoh MPC2000
                    Kinda like putting more gas in your tank because the engine has a high speed miss.
                    • PCTECHMECHANIC
                      • Jun 2015
                      • 14
                      Re: Ricoh MPC2000
                      Thank you to those of you who had a suggestion.
                      • bob marley
                        • Jan 2012
                        • 1339
                        Re: Ricoh MPC2000
                        clean the laser unit glass
                        Live for yourself and you will live in vain. Live for others, and you will live again
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          Re: Ricoh MPC2000
                          Is the page being fed LEF or SEF?
                          This model supports both.
                          IF it's SEF, it could be something as simple as a developing cylinder not always turning: bad clutch, gear, etc...
                          Note that there is no distinct break between the good and bad areas; it somewhat is progressive.
                          i had a Canon machine do that to me years ago, it turned out to be a bad clutch. It drove me nuts until I found it.
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Re: Ricoh MPC2000
                            Keep pounding the learning curve pavement there PCTechmechanic.
                            You'll soon learn around here that the bark is worst than the bite.
                            They're mostly a good bunch of strays blokes.... (whoops women too)
                            • PCTECHMECHANIC
                              • Jun 2015
                              • 14
                              Re: Ricoh MPC2000
                              Cipher,
                              That did the trick. I cleaned it and voila no more problem. Thank you very much for your time and help!
