scan to flash in mp2501 sp
  • en.
    • Jul 2014
    • 124
    hi sir
    i want to know how i can mace scan to flash memory in mp2501 sp
    best regards
  • trc
    • Jan 2007
    • 95
    Re: scan to flash in mp2501 sp
    In one side of the operation panel, is located a slot where you can place the USB device....then select scan to usb in operation panel...
    • en.
      • Jul 2014
      • 124
      sir
      there is no scan to usp in operatinal panal
        • 36831
        Originally posted by en.
        sir
        It is not labeled as "Scan to USB". In the scanner application, select "Save File" at the top of the touch screen. From that screen select "Memory Device". If you have the USB drive plugged in to the side of the control panel, select it and press start.
        • wilbert.c
          • Apr 2014
          • 24
          by default the machine come without HDD and it is required for scanning to USB therefore make sure the machine has HDD installed
          • copyaction
            • Oct 2007
            • 985
            I believe if it is the SP model it should already come with HDD
            • Polo-022
              • Sep 2007
              • 481
              • Polarbear
                • Feb 2012
                • 1070
                That is not true! Ricoh tries to tell you that and sell the same BS for the MP301. you can scan to flash fine without a HDD.
                MP301SPF scan2usb.pdf
                We program a shortcut to the MP2501 and MP301 as well as other "chocolate and cream" colour machines and all work.
                I attach the method we use. It can be adapted for all other machines in the new Ricoh line-up that support inserting a USB device on the op panel and have scanning as an option.
                Enjoy!
                Press the GREEN button!!
                • hdmr
                  Helpdesk Engineer
                  • Feb 2013
                  • 51
                  I think the below needs to happen - its an SP mode you would enable then a setting in user tools:
                  You have to enable a feature in the Scanner SP mode, to do this follow these steps;
                  • Press the Yellow Clear all Key, type 1 0 7 and hold down the Red Cancel Key until there is a change in display.
                  • Select the Scanner SP option.
                  • At the top right hand corner of the screen SP Direct should be highlighted.
                  • Type in 1013 001 and press the hash key # on the left of the screen.
                  • Input the number 1 into the box on the right hand side of the screen and press the hash key to confirm.
                  • You will now have a window asking you to , using the main on/off switch on the left of the machine switch the device off for 5-10 seconds.
                  • Switch back on and the feature is now ready to use.
                  • Polarbear
                    • Feb 2012
                    • 1070
                    No sp mode is necessary. Have a look at my attachment in my post. All is programmed in UP mode.
                    • Sashko
                      • Oct 2009
                      • 110
                      Machine support only FAT16 and FAT32.
                      Support SD card with a maximum capacity of 2GB.
                        • 36831
                        I get "Invalid Attachment specified. If you followed a valid link, please notify the administrator" when clicking on your attachment.
                        • Polo-022
                          • Sep 2007
                          • 481
                          ...anxious to read the polar attachment!!!
                          • rsyarcia
                            Hair Straightener Tech
                            • 711
                            This model needs a HDD for scan to USB(flash) to work. Hdd is an option even for SP. All the settings from the SP mode are enabled by default.
                            Nobody is perfect..
                            • fshead
                              • 2356
                              [ATTACH]31800[/ATTACH]
                              Enjoy!
                              thnx but your attachment does not comes up
