MPC6003 SC561 will not reset
  • kannuki2
    • Feb 2012
    • 398
    Hi guys, anyone experience an SC561 that will not reset. I replaced new thermistors and thermostats, used SP5810-1 and SP5810-2 (failed). Any ideas will be appreciated.
  • cooljeb
    • Jan 2015
    • 18
    Re: MPC6003 SC561 will not reset
    Hi I think you will have to replace fuser unit or the reset fuse in fuser unit same as the MPC--02 M/c
    • kannuki2
      • Feb 2012
      • 398
      thanks cool, I forget to mention that I did slide the D144fuse in three times and popped all the fuses when I ohms it out. However, the sc561 remains.
      This is a whacky machine.
      • cooljeb
        • Jan 2015
        • 18
        check service book page 493
          • 37532
          SC 561 is a pressure roller thermistor error. If you have already replaced the thermistor, check/replace the pressure roller thermostat. Check/replace the pressure roller lamp. Every time I have had a color machine with SC 561, the pressure roller thermistor has been open.
