Ricoh 3245 duplex printing issues
  • Lagonda
    • Aug 2008
    • 1649
    Got a 3245 that wont let you print a duplex job.
    Can photocopy using duplex with no problems.
    Have tried both RCPS and PCL6 drivers and even printing from a laptop and cross over cable but still can't duplex. Go into driver set up and it wont even let you tick the duplex option box as its greyed out. Anybody any ideas?? (and yes, firmware was the first thing we tried!
    Cheers,
  • NCArt
    Mountain Tech
    • May 2008
    • 81
    Cheers,
    Do you have admin rights?? Are there user codes needed?? Sounds to me like you don't have the authority to all options under user management.
    • schooltech
      School District Tech
      • Jun 2008
      • 504
      This may be an obvious question, but did you go into accessories and tell it that it has a duplex unit?
      Some of the Ricoh drivers need you to tab over to accessories and let the driver know what options are on the copier.
      Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
      • Lagonda
        • Aug 2008
        • 1649
        Yup tried that, duplex option not available i.e. greyed out.
        • FMC
          • Aug 2008
          • 88
          By the sound of it you don't have admin rights.You'll need to ask whoever looks after the IT do either change it, or ask them to give you admin rights.
          • schooltech
            • Jun 2008
            • 504
            What is the environment that you are installing them in? I think NCart and FMC are correct about not having the proper rights for full print-properties functions.
            At least that would be the next step to look at.
            I'm guessing then that you are installing it in a domain environment, and the computer you are installing it on is not an admin or a power user or something.
            • rthonpm
              • Aug 2007
              • 2859
              If it's a common print driver on a server, the admin is going to have to change the properties on the shared driver. From there all of the users will get the change broadcasted out to them on their next log on.
              • FRIDGEMAGNET
                • Aug 2007
                • 377
                You say you have a Ricoh 3245 - is that the color 3245?
                If it is the color - I had one that had the default output tray set to "external tray".
                Duplex is not available when this is set.
                This is in user tools - system settings.
                • Lagonda
                  • Aug 2008
                  • 1649
                  Yes its the colour 3245.
                  If its an Admin rights problem why can't I duplex with a laptop and cross-over? that will bypass the network.
                  • Lagonda
                    • Aug 2008
                    • 1649
                    Fixed it!!
                    And Fridgemagnet wins the Tech of the Month Award!!!!
                    Set the output to go via the finisher and the duplex works again.
                    Cheers Fridgemagnet, Goodonya!
                    • schooltech
                      • Jun 2008
                      • 504
                      If I ever 'have' to run into a 3245 again, I will definitely remember this one. Excellent find and a weird setting that you wouldn't think would affect it the way it does.
                      Thanks for letting everyone know that Fridge fixed it.
