1027 PCU
  • totoro
    • 568
    1027 PCU
    Hi Guys,
    I am fairly new to the Ricoh copiers and have a question for you old timers. I have heard a lot of techs talk about using the 1027 PCU in other models. Can someone tell me which other models this PCU will work in? Also what mods ( if any ) need to be done to make this work. Any info will be much appreciated.
    TIA Totoro
    Totoro
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    The 2022/27, I believe the 3010's and related series as well.
    I read on one of the threads about being able to use them on a newer box as well I thought, but I would think that they would have CQ problems.
    I'm sure someone else can chime in on this one with additional info.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • Star
      Ricoh Tech
      • 127
      Has worked fine in the 3025/3030 for me so far.
      Regards
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Ditto, for me. The newer boxes can have the PCU installed without any issues (so far). It's much more expensive than rebuilding the units, but in a pinch it can be done. When the developer gears crap out it's nice to know you can slap one in and get a customer back up and running.
        • totoro
          • 568
          Thanx guys, I appreciate the info. Does that mean that the 3030 PCU will work in a 1027?
          Totoro
          • cobiray
            • Mar 2008
            • 1199
            I've never tried to see if the units are backwards compatible, but I have to believe that it would work. Do you have a specific reason why you would want to do that? In my experience the PCU units are much more trouble free than the rebuildable ones.
            • TonerMunkeh
              Professional Moron
              • 3865
              The type 1027 PCU will work in everything from the Russian-C2 (1027) up. I think the old one (220 / 270) is the type 320?
              Hit it.
              • rthonpm
                • Aug 2007
                • 2859
                The 1027 PCU will fit in the following models with no modifcations:
                1022/1027
                2022/2027
                3025/3030
                MP 2510/3310
                MP 2550/3350
                With a slight modification it will also fit in the 220 and 270. Just remove the set pin on the right side of the front of the unit. I have used them in it with no issues at all.
                As for backwards compatible, there are extra pins on the back of the newer PCU's, and also a few different shapes. The 1027 all in one unit works so much better in my opinion than the rebuild-as-needed ones that I only use the assembly. Since it lasts past its yield, the cost per copy on service calls goes down and justifies the expense over rebuilding.
                • totoro
                  • 568
                  Cobiray,
                  I was just asking for the sake of my own curiosity about whether they are backward compatible. Who knows what info will come in handy someday?
                  Thanx Totoro
                  Totoro
