Ricoh MP C4501
  • Lotar
    • 76
    Ricoh MP C4501
    Greetings,
    I am looking for the information regarding the Drum Mods for the Ricoh MP C4501, can the drums be modified like in the MP C4500 ect..?
    can anyone provide a link or possibly the part numbers that can be used ?
    thank you for any assistance
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP C4501
    The black is unique to the 4501 because of the hoofing great big lube bar. Not sure on the colours but they are cheap enough anyway.
    Hit it.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Re: Ricoh MP C4501
      As it's hardly a secret.
      B2242042 drum units can unofficially be used for C/M/Y.
      Just grind down the corner of the connector with the pin so it fits (an Dremel makes a quick and tidy job of it).
      • jfbar1
        • Oct 2008
        • 53
        Re: Ricoh MP C4501
        NO offence, but that hasn't been true since the MPC4500 series (Back in 2008). It's true the black PCU for the 4501 has a larger lube bar and can not be used for the color. I found this out the hard way by completely disassembling it to try to rebuild a yellow one in the field.
        • Cipher
          • May 2006
          • 1309
          Re: Ricoh MP C4501
          Incorrect.
          B2242042 are good to use for C / M / Y up to the 02 range.
          The 01 and 02 have unique k drum units, and 02 have back plates that need cutting off, but apart from that your good to go.
          Either that or I have just been lucky a few hundred times.
          • UCPrint
            • Oct 2012
            • 24
            Re: Ricoh MP C4501
            I have attached a cheat sheet that someone posted on here that shows you how to mod the different models! just waiting for someone to figure out how to do the 03 models now
            B2C_Drum_Cheat_Sheet_v3.pdfB2C_Drum_Cheat_Sheet_v3.pdf
            • jfbar1
              • Oct 2008
              • 53
              Re: Ricoh MP C4501
              Never knew the trick about swapping the wires for the d027 series and newer. Would have saved a lot of parts calls back in the day. Thanks for the PDF
              • Imprestik
                • Aug 2012
                • 296
                Re: Ricoh MP C4501
                Use the PCDU maintenance kits from the SPC830 into these, they work perfect with only slight modification for them to work
                • Gift
                  • Mar 2011
                  • 2444
                  Re: Ricoh MP C4501
                  Good luck with it^^
                  I've already noticed that ricoh did more changes between BK/COL units like slight different position of gears/shafts.
                  It might be possible to strip parts out of a BK unit and rework a COL unit but I haven't tried.
                  Whatsoever it's going to be much more effort than filing a corner off or swap some wires^^
