Need help with Word Perfect
  • eescamilla
    • Aug 2015
    • 58
    Upgraded a customer to a MPC4503 from a MPC4500. I don't know much of Word Perfect but they showed me when creating a document, they have these codes that you can insert into the doc that tells the printer you want to print on certain size paper and type (in this case on letter, type letterhead, tray 2). On the 4500 it would automatically do so picking tray 2 which is set to letterhead and letter. On the 4503 however it will not select letterhead or letter. It will want to print to tray 2, it just asks for plain/recycled and custom size.
    I've tried switching from pcl6 to pcl5 and same issue happens. I did get it to work by creating a preset within the pcl 6 menu but the customer says "they shouldn't have to do this". Any help?
  • qbert69
    • Mar 2013
    • 1152
    Re: Need help with Word Perfect
    Good Luck with your Quest!...I totally DESPISE Word Perfect!...why???...I have had issues (in a lawyer's office...they absolutely *love* Word Perfect!...for whatever reason, I don't know!) where when a system print driver was locked down to only print black & white, the print settings in Word Perfect would OVERRIDE the black & white default and print in color!!!...DOH!
    This may be an issue that THEY have to direct to Word Perfect Support, especially if it is a function of the Word Perfect Program itself!...If you have determined that it is not a fault of the print driver in and of itself, you need to bow out and say the "buck stops here"!...you can waste alot of time on program specific problems!
    Case in point...we have a local tire service center that has invoice software (independent developer!) that prints out graphics on the invoice. Long story short, they were getting charged for color because *their* program which was using greyscale JPEG's was forcing the printer to print process (CMYK) B&W even though the system print driver was defaulted to B&W! Fix was to change the graphics to 2 bit strict B&W bitmapped (.bmp) graphic!...*fixed* it in photoshop!...DOH!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • sandmanmac
      • 3981
      We're going back a few years so my memory is a little foggy, but I had a similar instance with a client using WP. They were printing to an MP161 with letterhead in Tray 1.
      I can't remember exactly how I resolved it, but I managed to, with a bunch of trial and error. I even got myself a copy of WP to install on my PC, and had the exact same problem -proving that it was a software issue and NOT the machine!
      It seemed to just ignore any preferences I selected prior to printing.
      I think the end result was something like installing a separate copy of the print driver, locking all settings in printer properties to the corresponding tray and naming the printer "Letterhead" printer, similar to what you've done, but maybe a bit more convenient for the end user (?)
      The bottom line is that it's a software problem or limitation - and they'll have to live with it whatever the workaround is for their particular model
      NOTE: You do have the "Letterhead" tray, set to letterhead setting, correct?
      Good luck
      • sandmanmac
        • 3981
        Just another thought on this topic....I've had a couple of clients that didn't want to go the "user code" route particularly, but wanted me to disable colour printing to certain individuals, so I simply installed a B&W printer driver on the PC instead of the colour model.
        Maybe this would have helped resolve your issue too? Even though, I agree that the DAMN software should just respond to driver commands!
          • 37511
          User Tools - Printer Features
          Under paper settings,set tray 2 for driver/command instead of machine.
          • NeoMatrix
            Senior Tech.
            • 3513
            I agree with Slimslob :
            I've never played with Word-Perfect software to find out for sure, though I believe setting the MFD for driver/commands
            should able it to respond to the PCL codes sent from the PC software.
            HTH
            • sandmanmac
              • 3981
              I kind of wish there was a 'Dislike' button (kidding) - Only because of the amount of time I spent on this trying to find the solution, and you're probably right on the money with the simple FIX!
              • eescamilla
                • Aug 2015
                • 58
                I will try this out this week thanks
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  I agree with SlimSlob's suggestion, but if it doesn't work...
                  It's not available for the newer machines, but try either the PCL5 or 6 (preferably 5) mini driver,
                  The C4500 mini driver is available, and should work. (Notice the should part...)
                  It's a very lightweight driver without the fluff.
                  WordPerfect insists on doing the proverbial driving, and the mini driver seems to listen.
                  I had a law firm a few years back with a similar situation. Their WordPerfect jobs called for simplex and duplex in the same job. The PCL 5 mini driver worked great.
                  Disclaimer: I have also noticed that the PCL interpreter of the newer machines are different compared to the older ones: a lot of tricks that worked before no longer do. I had a customer who printed from DOS to an 01 machine, and the same jobs failed on the 03 (long story on that one).
                  The rules of PCL do change from time to time. Ricoh is not being difficult, they are simply keeping up with the changes.
                  • qbert69
                    • Mar 2013
                    • 1152
                    I think I need to send a *n@$tygr@m* tellin' 'em to get their *sh!znit* together and clean their software up!!!
                    It's just ridiculous that you have to go through so many settings just get WP to print correctly!...and consistently!
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      I agree.
                      Unfortunately, the legal world (as well as some healthcare) will never let it go.
                      There are many more options in WordPerfect than in MS Word, which they rely on.
                      Keep in mind that back in the day (maybe the late 80s and early 90s), that WordPerfect for DOS ( I think version 5.1), was pretty much the ONLY word processor out there. That was how WordPerfect got its foothold on the business world. The move to Windows was only natural.
                        • 37511
                        There is absolutely nothing wrong with Word Perfect. Any time you have a red light on the printer function and see the message "Please insert _______ Paper and ______ size" you need to set driver/command instead of machine. When the tray is set to machine it uses the paper size and type set in user tools fro all jobs, copy and print. If the desired paper setting does not match you get that message no matter what the software. When set for driver/command the machine accepts the settings sent by the computer.
                          • 37511
                          Originally posted by KenB
                          I agree.
                          No, Word was available. So was Word Star. Word Star had such crappy documentation that every reviewer wrote their own manual on how to use it. This made a lot of people buy it because there were so many books on it it had to be good. They soon found out different.
                          In the early days of word processing, Word Perfect allowed you to select the desired printer from within the software. Word used the default printer. If you wanted to use a different printer, you had to exit Word and change the default printer. One of the biggest pluses to Word Perfect is that it can do many of the document operation that with Microsoft you have to purchase Publisher.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            It's not the easiest application to work with, but it can do things MS Word never dreamed of.
                            • Tonerbomb
                              AutoMajical Resolutionist
                              • Feb 2005
                              • 2589
                              I agree.
                              Don't forget about the religious organizations also that still use WP..................what a PITA sometimes......................
                              Mystic Crystal Revelations
