Ricoh FT4822
  • Gab
    • Aug 2015
    • 671
    Ricoh FT4822
    I replaced developer ,performed sp 2214. At the beggining image was ok but after 1,2 days image became too light. Toner is OEM ,
    Can anybody tell me where the problem is?
  • sandmanmac
    • 3981
    Re: Ricoh FT4822
    Well "HELLO again, 1998"!
    I can't believe I'm even going down this road with you, but first, I want you to tell us what else you did?
    Surely, you didn't just replace the developer, run SP2214, and walk out the door?
    Surely, you at least cleaned the optics, Charge roller, and shield glass, and ran the VERY important auto and manual image density settings in SP mode too?
    Surely you did??!!
    • Polo-022
      • Sep 2007
      • 486
      Re: Ricoh FT4822
      Hi Gabby,
      maybe you forgotten the Toner end sensor disconnected!!
      • Gab
        • Aug 2015
        • 671
        Re: Ricoh FT4822
        Originally posted by Polo-022
        Hi Gabby,
        No i didn't , i allways check itAlsoi cleaned optics etc and executed sp 4001, 4201 and 3105.
        have to execute any sp?
        • sandmanmac
          • 3981
          Re: Ricoh FT4822
          Good. You see why it's important, and helpful for you to give as much information as possible in the first place.
          Then, I'm guessing that the issue is either a worn out dev roller gear or a broken Auger gear
          • bob marley
            • Jan 2012
            • 1339
            Re: Ricoh FT4822
            do sp2-207 ( Forced Toner Supply) and sp 3-001( ID Sensor Initial Setting) check sp 2-802 (drum charge roller temperature)
            Live for yourself and you will live in vain. Live for others, and you will live again
              • 37533
              Re: Ricoh FT4822
              Did you go back and recheck it after you started having problems. And do not just look at it, I have made that mistake before.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Re: Ricoh FT4822
                You may want to check for excessive "dinosaur dust" inside this old geezer.
                Sorry, I just couldn't resist.
                • vargue
                  • Oct 2011
                  • 404
                  Re: Ricoh FT4822
                  replace this(( junk )) tell customer that spare parts not exist .and make a favor on him
                  • trc
                    • Jan 2007
                    • 95
