MPC3002 5502 thick stock
  • tufbnme
    • 493
    Can someone enlighten me as to what it takes to run thick stock on these machines without it not fusing the toner? I have tried all the thick settings within the print driver. On multiple prints it still does not fuse completely.
    I have replaced the fusing film with the new style, changed the sp settings according to the bulletins but still nothing.
    What am I missing?
    I am running 110lb/199g/m2 stock
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MPC3002 5502 thick stock
    What am I missing?
    All Media is not the same based on weight, so 110#/199gsm what?? text, cover, CS1, CS2, card stock ect...............
    I've got one that gives what looks like cold fuser offset on 11x17 20# copy paper only on the 5" of the trail edge, Haven't figured it out yet.............
    Mystic Crystal Revelations
      • 37493
      What is set in the driver as far as thickness has no effect unless you set Command/Driver for the paper tray in the Printer portion of User Tools.
      • tufbnme
        • 493
        So I need to tell the machine first that a certain tray is a certain weight then the thickness controls will work in the print driver?
        Also there is a bulletin on the cold fusing at trail edge.
        bulletin.pdf
        • tufbnme
          • 493
          I checked it and the bypass is set for driver command which is where I was running the paper.
          • Gift
            • Mar 2011
            • 2459
            One should notive if the paper type setting won't work if the process speed won't reduce.
            Is it some sort of coated/special paper or just thick color copy paper?
            • tufbnme
              • 493
              It is not a coated or gloss. It is 110/199g/m2 white stock. I think it is index.
              20150904081139880.pdf
              • Tonerbomb
                • Feb 2005
                • 2589
                [ATTACH]30503[/ATTACH]
                That's about 53# bond, definitely a thick paper setting
                Paper weight comparison and more
