SMB Versions Explained
  • RicohSharpBoy
    • Sep 2015
    • 12
    I'm wondering if anyone has a list of what Windows OS work with what Sharp and Ricoh models, as far as SMB scanning goes? I'm curious because we have been seeing a lot of MFPs not working with Windows 8, Windows 10, and Windows Server 2012.
    Does this have to do with SMB versions, and/or the level of encryption?
    (I know firmware updates can fix many of these SMB compatibility issues, but it would be extremely helpful if there was some type of list out there)
    Thank you in advance!
    • 36815
    Re: SMB Versions Explained
    Yes. Windows 8/Server 2012 introduced SMB 3. Firmware updates are needed to use scan to SMB. Other option is to use scan to FTP.
    • RicohSharpBoy
      • Sep 2015
      • 12
      The problem with FTP is some of our customers are stubborn and want to use SMB only. Speaking of FTP, what other software besides Filezilla is commonly used for scanning?
      Any idea on a list that Sharp or Ricoh has put out about SMB versions on each model?
      • sandmanmac
        • 3964
        Slimslob pretty much summed it up. A list isn't necessary, because it's just understood:
        Machines introduced prior to Windows 8 need firmware for Win8/10. Or, If a customer upgrades to Win8/10 and scanning ceases to function - it needs firmware.
        Your customers are stubborn? Curious, how using FTP affects them? The operation, from their perspective, is exactly the same, and is often easier to manage from yours. For example, in cases where account passwords change regularly.
        To me, Filezilla is the simplest/easiest to setup, and I've not had a moment's problem with it.
        I've messed around with Xlight, in the past. The interface is quite similar to Filezilla, but configuration is not nearly as easy imo
        • rthonpm
          • Aug 2007
          • 2847
          Related to your question, here is a page from Microsoft explaining the differences in SMB over the past few versions of Windows: Windows Server 2012 R2: Which version of the SMB protocol (SMB 1.0, SMB 2.0, SMB 2.1, SMB 3.0 or SMB 3.02) are you using? - Jose Barreto's Blog - Site Home - TechNet Blogs Generally, the security and performance get stronger.
          • RicohSharpBoy
            • Sep 2015
            • 12
            Thank you all for your replies. A lot of helpful information here!
            • RicohSharpBoy
              • Sep 2015
              • 12
              I should have been more specific...
              I'm not referring to your basic non-IT office worker having a problem with FTP. They don't know the difference between SMB and FTP. It's those times when you work with a customer's IT department, and they don't want to use FTP scanning for whatever reasons (security is a big one).
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                Here's the link for the how to disable smb v1,v2.or v3: https://support.microsoft.com/en-us/kb/2696547
                The newest is v3 thats what has caused all the pain from MicroSh!t................
                Mystic Crystal Revelations
                  • 36815
                  In other words they are too lazy to set it up.
                  Most of the work around have seen for forcing Windows 8 to use pre 3.0 SMB do not always work, or they work until Microsoft sends out a security update.
                  • londonprideman
                    • Feb 2012
                    • 4
                    Hi, don't know if this will help anybody, but I found the following.......and can now scan to Windows 10, using SMB on a Ricoh MPC2800 in the workshop. I was looking for a fix for Konica Minolta Bizhub C280.....this also works!!!!
                    For some reason, still struggling to get it to work on a MPC2500.
                    SMB Scan to folder in Win 10 evaluation copy. - Microsoft Community
                    Scan to folder works with the following settings.
                    Your network connection type has to be set to Private.
                    The advanced sharing settings have to be set to: network discovery "on", file and printer sharing "on",
                    public files can be seen by all on network "on" and
                    turn off password protected sharing (Ricoh machines only send the login info once, not at every level.)
                    The folder properties must be set to: ready to archive (advanced button on the general tab,)
                    advanced sharing permissions to allow everyone full control.
                    I hope this helps. Ian
                    • qbert69
                      • Mar 2013
                      • 1152
                      I have had to use this before in doing SMB on a Mac!:
                      SMBUp | eduo.info
                      ...and as far as the various SMB versions, here is a bit of *comedy* to illustrate!:
                      yes....my thoughts EXACTLY!!!
                      ...why does it have to be so DAMN DIFFICULT!!!
                      REACH FOR THE STARS!!!
                      Konica Minolta Planetariums!
