Ricoh MP 2500 replaced Print/scan controller
  • StephenB
    • Aug 2015
    • 239
    Had a customer get hit by a surge, dead print controller. Hytec no longer supports this, NWRS tried their best but too damaged. I found a "recycled print controller. Swapped the NV RAM from the original board. Everything functions except I cannot enter scan destinations, The web interface on the opening page shows the available functions, copy, fax, print and scan. However there is not a scan area in the configuration and the address book does not show a scan destination. I can manually enter an email address and it does send.
    I performed a memory clear all, still no help. Also I cannot "browse" their network to manually search for a scan to folder. Almost acts like I don't have permission to access the scan functions.....???
  • Moza
    • 232
    Re: Ricoh MP 2500 replaced Print/scan controller
    Sounds like you are missing the HDD ??
      • 37358
      Most likely the surge fried the HDD.
      • StephenB
        • Aug 2015
        • 239
        This is a MP 2500, (not MPC ) There is not a HDD on this system. I can enter fax destinations, just not scan destinations ( folder or email )
        • mikedci
          • Jul 2010
          • 227
          If the MP 2500 has a print/scan sd card make sure its in the correct slot. Have you initialized the address book? 5-846-050
          • sandmanmac
            • 3979
            Had the exact symptoms described by the poster, with a previous generation of this machine. Customer had picked up the machine (somewhere), and couldn't get the scanner to function. SD card was in wrong slot.
            • StephenB
              • Aug 2015
              • 239
              I had performed SP5-801-1 but have not done 5-846....Thank you .
              And I do have the print SD card in the upper slot , lower slot contains address book SD
              thank you
              • sandmanmac
                • 3979
                thank you
                I think you might want to reconsider your position.
                From the manual:
                SD Card.pdf
                I believe the address book card is redundant once the print/scan card has been installed
                (please correct me if I'm wrong)
                • StephenB
                  • Aug 2015
                  • 239
                  From the manual:
                  [ATTACH]30546[/ATTACH]
                  Wow, and I was "so careful" when changing out cards from board to board...sometimes just get "tunnel vision" Thanks for the help.
                  • StephenB
                    • Aug 2015
                    • 239
                    From the manual:
                    Wanted to thank everyone for assistance. Just returned from clients system and the SD card was in the wrong slot.
