Ricoh MP 5500
  • PinevskiS
    • Jul 2009
    • 283
    Ricoh MP 5500
    Hi,
    I have Ricoh MP 5500 and I make to print on 40 g. thin paper at bypass. When I print on bypass , copy is on the down site on paper because paper path is on duplex unit.How can I enable duplex path to copy come on the top site in paper?
    Thanks.
  • Gab
    • Aug 2015
    • 671
    Re: Ricoh MP 5500
    Originally posted by PinevskiS
    Hi,
    Thanks.
    Ithink you can't copy with duplex when you use by pass
    • techsass
      • Dec 2010
      • 248
      Re: Ricoh MP 5500
      Not sure if this is what you're asking about. In USER TOOLS > COPIER/DOCUMENT SERVER FEATURES there's a setting for BYPASS to eject Face Up/Face Down.
        • 37491
        Re: Ricoh MP 5500
        Check Printer Preferences - Detailed Settings tab - Finishing for eject face up option. You may need to try a driver for a later model.
        • PinevskiS
          • Jul 2009
          • 283
          Re: Ricoh MP 5500
          Thanks .
          • PinevskiS
            • Jul 2009
            • 283
            Re: Ricoh MP 5500
            I try to enable the paper path to not go in duplex unit if I make a print , does anyone knows in SP mode, have any options to setup the paper go only right (bypass-transfer-fusing and exit unit).I try everything I know.
            Thanks.
              • 37491
              Re: Ricoh MP 5500
              Thanks.
              It appears that "Eject Face Up" is not supported prior to the MP 6001/7001/8001/9001.
