MPC4500, I dont want GlobalScan on the Scanner, How can I use the Standard Scanner ?
  • mterrero
    • Sep 2011
    • 60
    [Misc] MPC4500, I dont want GlobalScan on the Scanner, How can I use the Standard Scanner ?
    Hello,
    I have received a Print Controller for a Ricoh MPC4500 with GlobalScan when the scan key is Push,
    How can I used the standard Scanner ( I need to used Scan to Folder )
    How can I disable or unistall the GlobalScan ?
    Thanks for your Help
  • mikedci
    • Jul 2010
    • 227
    Re: MPC4500, I dont want GlobalScan on the Scanner, How can I use the Standard Scann
    Try hitting the scan button a second time. It should toggle between globalscan and the standard scan function unless the standard scan function was removed. Uninstall globalscan through user tools > extended features.
    • mterrero
      • Sep 2011
      • 60
      Thanks Mikedci, problem solved...
