I only seem to be able to email to yahoo email. If I try to email a scan to anyone else at another domain, gmail, randomdomainname, etc, I get an error code.
I have, several times. I can email to the address from a PC connected to the same network to the address, but when I specify the address using the manual input when emailing a scan, it errors. I can [OK] the error, go back and change the send to email address to something@yahoo.com and it works perfectly.
Try enabling SP5-860 for "SMTP From Replacement". This will allow the sender name in the admin email address to be part of the authentication. Otherwise use a smtp relay server program such as Mercury Mail to forward the scans.
Do what you can, with what you have, where you are. ~Theodore Roosevelt
Sounds like something in your settings. You can email normally on other networked pc's so check and copy the settings from that pc. run ipconfig /all from command. Make sure the DNS settings are the same and any other aplicable settings are the same. Firewall possible. Setup a new email account on your laptop using your customers network and see what happens.......Ant
