Ricoh MPC305 : Fax Number Ring
  • AleLeader
    • Oct 2012
    • 29
    I have new Ricoh MPC305 but i can not found where increase the number of rings when received FAX.
  • francisco
    • Nov 2009
    • 168
    Re: Ricoh MPC305 : Fax Number Ring
    SP mode fax sp
    NCU param.
    2-103-07
    by default is 2
    • sandmanmac
      • 3979
      Originally posted by francisco
      SP mode fax sp
      NCU param.
      2-103-07
      by default is 2
      Correct....you could also open a PDF of the service manual (any model will do because the process is the same on EVERY unit), and search : "rings"
