mpc4502 sr3110 jam198
  • ash_572
    • Oct 2008
    • 523
    [Jamming] mpc4502 sr3110 jam198
    i have a mpc4502 with a sr3110 booklet finisher that is giving a intermittant jam code of 198 (finisher fold)
    booklets are jamming just before it has turned over into the folder unit. i can see its catching something at the middle of the booklet while it is turning it over (stack transport roller).
    customer does alot of a3 bookets of 3 a3 sheets.
    i replaced the mylars behind the booklet staplers and the stack feed out belt.
    has anyone else had this problem??
    help is appreciated
  • rookiedave
    Re: mpc4502 sr3110 jam198
    Ash, the problem you are experiencing is very similar to mine. I would double check lower mylar on the B700 4250 Exit Belt: Ass'y. Check if it is laying flat on the belt. The movement of the feed out belt is tricky. Once the paper goes into the staple tray, the belt reversed the rotation to straighten out the paper for stapling. If the mylar is caught underneath it will creates weird jams. The quick and easy way to duplicate the problem is by running letter size papers and do fold & staple. There will be one or two pages will not staple in the middle of the stack.
    • ash_572
      • Oct 2008
      • 523
      Hi mate
      i have replaced the belt exit addy. Same part number you describe and still get jams.
      Is the Mylar on the belt assy? If
      not can you give me the part number please?
      thanks
      • Dragord
        • Sep 2014
        • 5
        Hi I have a 5502 with a SR3110 throwing up j198 and also logging a j204 when i try and create booklets.
        It completes one booklet and has one stapled and not folded, one waiting, assembled but not stapled or folded and one still being printed.
        It sounds like your fault did you ever find a solution?
