"Set Fusing Unit Correctly" and SC142
  • kannuki2
    • Feb 2012
    • 398
    Hi all, I have a MPC6501 or prodoct code081 with the following errors above. The "Set Fusing Unit Correctly" will not go away after I replaced the fuser's belt and thermistors.
    Original problem is the machine was off and fuser's belt was ripped and binded up. So I didn't even bother to power on the MFP and went ahead and replaced the fusing belt and thermistors. After I powered on it gave me the errors. I ohms out all the lamps and check the connectors on the rear frame and fusing unit good. No obstructions or bent. What can cause this ? Any ideas will be appreciated.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: "Set Fusing Unit Correctly" and SC142
    Do you have two machine faults at the same time ?
    SC142, I believe relates to Scanner.
    Is there a fuser code ?
    SC142 : Dirty optics and or white plate. Scan motor not homing ?
    Fuser set error: Is there paper jambed in the connector. Thermistor on upside down ?
    • kannuki2
      • Feb 2012
      • 398
      Thanks neo, same copier with two errors after fuser rebuilt. The SC 142 did not appear before I reseated the connector in the back of the fuser
      • NeoMatrix
        Senior Tech.
        • 3513
        As I see it the only thing really common to both of those faults at the same time is the Power supply.
        Have you've got a voltage rail out or have you fixed/wired something to ground/frame ?
