SC 302 in Ricoh Aficio MP 1800 L2 & SC 402 in Ricoh Aficio C2030
  • 1978chaya
    • Sep 2015
    • 8
    [Error Code] SC 302 in Ricoh Aficio MP 1800 L2 & SC 402 in Ricoh Aficio C2030
    please send me to clear this error in my Ricoh Aficion MP 1800 L2 to mail id : 1978chaya@gmail.com
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: SC 302 in Ricoh Aficio MP 1800 L2 & SC 402 in Ricoh Aficio C2030
    SC402 code Mpc2030----manual says separation issue. Maybe transfer roller assembly is dirty and shorting out. Make sure transfer roller is mounted/installed correctly.
    L2 code MP 1800-----I don't recognize that code. SC codes are normally 3 digit numerical codes on the B245/276/277 series. Some manufacturers use L codes to denote issues with the laser failing.
