Ricoh Aficio MPC 4500 SC 290
  • bernardo749
    • 42
    [Error Code] Ricoh Aficio MPC 4500 SC 290
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh Aficio MPC 4500 SC 290
    English, please.
    Dear,
    This is to please ask for their support and help.
    I have a photocopier Ricoh Aficio MPC 4500 with error SC 290, Segui several posts in the forum relating to the error and follow the instructions given.
    Turn off the engine and remove the small metal arm that operates the sensors that open and close the shutter.
    It is necessary to reset the error?
    Any idea continues to show me the error SC 290.
    Greetings!
    NEVER ASSUME ANYTHING
    • mikadonovan
      • May 2008
      • 2931
      Originally posted by mikadonovan
      English, please.
      Dear,
      Greetings!
      Leave the arms and springs on, just remove the shutter itself to avoid a sc code.
      • skynetto
        • Sep 2012
        • 257
        2914-007 set it to Non present.
        • bernardo749
          • 42
          I think I am confused when you mean shutter, in this case would be the engine? You will have a referential image shutter please!
          I think I am confused when you mean shutter! The shutter for me is this:
          • skynetto
            • Sep 2012
            • 257
            B223 1885 Shutter Assembly. Its the metal plate on top of the laser unit.
            • bernardo749
              • 42
              This code does not appear in the service mode. Only the following codes in 2914:
              001 open delay time, delay time close 002, 003 Sutter open, 004 Sutter close
              • skynetto
                • Sep 2012
                • 257
                Stop reading the manual and try it on the machine. Its not listed in the manual
                • bob marley
                  • Jan 2012
                  • 1339
                  1. Check or replace the harness.
                  2. Replace the shutter on the laser optics housing unit.
                  3. Replace the shutter motor.
                  4. Replace the shutter close sensor.
                  5. Replace the IOB
                  Live for yourself and you will live in vain. Live for others, and you will live again
                  • bernardo749
                    • 42
                    Place the shutter assembly! It is difficult to remove? Will have at hand the steps to do? I'm tired of looking for technical and would not solve the problem. You have helped me with their advice, thank you very much!
                    • khattab.al.masry
                      • 212
                      the following attach picture display that there is no sp 2914-007 with mpc 4500.
                      this sp found in Mpc 2500 not Mpc 4500.
                      • bernardo749
                        • 42
                        Friends, will have by chance a picture assembly sutter please? Not the manual parties to reach me best!
                        • mikadonovan
                          • May 2008
                          • 2931
                          OK, here's my last attempt at help on this.
                          1. Open the manual to the replacement and adjustment section
                          2. Remove the laser assy following the procedure in the manual
                          3. Remove the big metal plate on top of the laser assy, leave the springs and arms attached
                          4. Reinstall the laser assy
                          5. If this was what was actually causing the code, the job is complete
                          • bernardo749
                            • 42
                            I removed the metal plate you see in the picture! Keeps throwing error! Thank you very much for your help!
                            • mikadonovan
                              • May 2008
                              • 2931
                              That's the one. Glad you got er figured out.
