parts and supply compatability on mpc2050 vs mpc2051?
  • fshead
    • 2356
    I am doing the switch over to mpc2051 s unit as my supply of low meter non yellow mpc2050s has dried up.
    I assume the drum units and dev units are interchangeable,are the fuser units?
    and can i use mpc2050 toner on a mpc2051?
    i know the mpc2051 black toner is available with hi yield but need to know where the account has left over mpc2050 toners.
    thnx
    • 36796
    Re: parts and supply compatability on mpc2050 vs mpc2051?
    thnx
    Fusing units are different.
    High yield toner ae available for all four colors. Color cartridges are interchangeable, black is not.
    • fshead
      • 2356
      thnx
      are the fuser belts the same?
      • TonerMunkeh
        Professional Moron
        • 3865
        Nope, fusers are completely different. They use a sleeve like the 02's. Dev units are different too.
        Hit it.
        • Polo-022
          • Sep 2007
          • 481
          Developer Units are the same.
          I use to replace them very often, they run about 60K prints,
          not the best part of this series.
          • TonerMunkeh
            Professional Moron
            • 3865
            Really? I tried to fit a 2050 dev unit to a 2051 and got PCU not set. I had to put the TD sensor from the old one onto the new one to get it to work.
            Hit it.
            • fshead
              • 2356
              thnx
              maybe the td sensor is wired differently,
              i guess ricoh would hate for us to be
              able to use leftover parts...
              I have nt had many parts go on the 2050 excluding
              pressure roller lamps and fuser sleeves.none are
              placed in high volume accounts.
              • Polo-022
                • Sep 2007
                • 481
                Well, i did replace a Yellow Dev. Unit from an MP C2550 to an MP C2051 two weeks ago,
                without a problem, without any modification indeed.
                Besides, the Parts Lists have the same part numbers : Β8093001,2,3,4.
                And yes, i have found a brand new D.U. where the TD sensor was defective.(Message : Set PCU corectlly)
                I think that this is what happened to you TonerMonkeh...
                • fshead
                  • 2356
                  Double-checked.....[ATTACH=CONFIG]30816[/ATTACH]
                  re I use to replace them very often, they run about 60K prints,
                  not the best part of this series.??
                  what type of problem caused you to change the units?
                  CQ?
                  NOISE?
                  • Polo-022
                    • Sep 2007
                    • 481
                    CQ?
                    NOISE?
                    Developer leakage at the rear side, ruins the PCDU totally, the drum gear especially!
                    Mostly happens if printing 11x17 format is the half part of the whole activity....
                    • masshoosier
                      • Jun 2015
                      • 5
                      The fusers are totally different....belt fuser with 2050...sleeve with 2051's. Black toners are NOT interchangeable but the colors are.
                      • Cipher
                        It's not easy being green
                        • May 2006
                        • 1309
                        All consumable PM parts are the same between the 2050 and 2051 except for:
                        Black toner bottle
                        Black dev unit
                        Fusing unit
                        Just to be 100% clear.
                        • fshead
                          • 2356
                          thnx
                          ok
                          good to know
                          i place mpc2800 and mpc3300 machine in any office with heavy
                          11 x 17 or heavier usage.
                          I m not a big fan of the mpc2050 design but they seem to work in low
                          count offices
                          • Cipher
                            • May 2006
                            • 1309
                            The 2050/1 are not that bad when on lower volumes.
                            The main bug bears being a less reliable method of paper feed and fragile plastic parts that go brittle.
                            We have swapped many of them out now with 2011s or better.
                            • fshead
                              • 2356
                              thnx
                              i m not a big fan of the paper feed or the right side plastic guides but
                              the machine is suitable in low vol accnts.
                              Is the 2051 fuser better or worse vs the mpc2050?
