Hi all.
I have a problem to set my Vsp to 0.5v. All I did was replacing the developer, replace the drum then run td sensor setting (sp2801), run id initialize (sp 3001).
Fyi, my current machine's readings are Vsg-4.23, Vsp-1.45. (very light image)
The toner indication always blink after a while even though the bottle is not empty. I need to manually pour some toner inside the dv unit to make the image brighter, but only last for few copies.
Anyone can guide me to get the Vsp reading to 0.5?
