1045
  • hodgiepodgie
    • Jul 2008
    • 284
    why is scanner feature not showing on op panel or user tool printer. controler is installed.
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    This machine uses a DIMM enabler for printing, scanning, and faxing. If the DIMM is missing for a particular option, then that option will not be available for use.
    • hodgiepodgie
      • Jul 2008
      • 284
      dimm card is installed .have fax option printer server but no scan feature on op panel or in user tool.
      • Star
        Ricoh Tech
        • 127
        At the beginning of production of the 1045, there were choices of print only or print/scan. (Later on, I believe you could only get print/scan.)
        Maybe you have a print only dimm?
        Regards
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          Regards
          Yep, Star is right. You said you´ve got a print server, sounds like your machine is a standard LPT port connected to a computer with printer share, that means you´ve got no print or print scanner installed. check that and then will see, oh bye the way do you have a RJ45 connection check that too.
          Hodgie
          • Baphomet
            Copier Technician
            • Aug 2008
            • 293
            Star has a good point.
            If you have the PRINT/SCAN DIMM then you need to leave the FAX DIMM off because it is not required, and if you have this DIMM combination installed it won't work correctly.
            If you have the PRINT and FAX DIMMs then you are missing the SCAN.
            • hodgiepodgie
              • Jul 2008
              • 284
              guess your right dimm must have printer /scanner on dimm.problem solved
              • hodgiepodgie
                • Jul 2008
                • 284
                yep got rj 45 forgot dimm has to say printer / scanner.oopsy
