MP 3601 Wide format
  • Dark Helmet
    • May 2009
    • 847
    MP 3601 Wide format
    Hi guys,
    Have a customer with a MP 3601 wide format printer. They use a cad called cadwork. When printing to the machine it will at random put a 45 degree line on pages that always intersects the edge of a 0 or a oval. The line is long. It does not always happen on the same page either.
    He said he had no issues with this for a long time and it started happening again. We upgraded the print driver but its still does this. Im going to look into firmware next. Apparently he had a OCE wide format and it did it with that machine as well which to me rules out the machine totally but i'd like to try and help him out if i can.
    Has any body ever had any issues with this?
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: MP 3601 Wide format
    I'm almost certain it is a software fault generated by user error.
    The elipse with a 45deg line is the ascii character zero "0".The elispse with a line represents the diameter symbol of a pipe or cylinder dimension.
    Check which drawing or file has a textbox,outline ,block,profile ,symbol ,dimension layer or character set container. See if the CAD file has hidden layers set with different colours that only print out on the printer, not the PC screen.The faulty zero character will be in the hidden layer on a rotated dimension view, most likely with a company profile outline or text block that gets copied and paste file to file.
    • Dark Helmet
      • May 2009
      • 847
      Thanks, half of that makes no sense to me but ill pass this onto the customer!
