Hi I assuming the Infotec isc2525 is the same as an mpc2500?
Anyhow the error 565 is showing up if copier cools down then I can get more copies out of it then after a while will show this code , again switch off then switch on will give some copies and then error comes back
I read some previous threads wondered if you this might be slightly different as copies come from time to time
Would hanging the thermostats any good ?
They don't seem to list many parts under the infotec name but hence assume identical to the 2500
