Print Quality
  • Killeromantic
    • Jul 2014
    • 37
    Print Quality
    hello I would like to know why Ricoh spc820 no longer printed with the same quality as the first, drum have its useful life in half and glossy papers prints come out dull and granulated much in the black.
  • Iowatech
    Not a service manager
    • 3930
    Re: Print Quality
    Probably because the developer part of the PCU is beyond factory specs?
    • Killeromantic
      • Jul 2014
      • 37
      Re: Print Quality
      manufactures specifications are 40k and the information sheet of the printer go through half of its useful life.
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: Print Quality
        The manufacturer specifications do not apply to a machine that is being run outside said specifications. Bear in mind these machines are office colour printers, supposed to do an average of 5% coverage. They are not, in any way, photo quality production machines.
        Hit it.
        • Killeromantic
          • Jul 2014
          • 37
          Re: Print Quality
          I understand what you tell me, but at first the leaves came out with a shine and gave the deep colors. I imagine that I can achieve all drum changing half his life with new ones.
            • 37491
            Re: Print Quality
            If you have not yet cleaned the laser shield glasses and the image density sensor assembly, you need to do so.
            • Killeromantic
              • Jul 2014
              • 37
              Re: Print Quality
              You mean the tool is to clean the plastic bar that is at the door from front, with that I've cleaned many times but everything remains the same. where before the printing quality was shiny and black deeper, now it is dull and grainy black more. as you clean the image density sensor assembly?
                • 37491
                Re: Print Quality
                Cleaning the image sensor is in the service manual.
                • Killeromantic
                  • Jul 2014
                  • 37
                  Re: Print Quality
                  oky thanks proves that
                  • Killeromantic
                    • Jul 2014
                    • 37
                    Re: Print Quality
                    that part because brightness when printing on a laser printer,
                    OEM compatible toner may not be the cause of the loss of brightness or print any component as the fuser.
                    • Iowatech
                      • 3930
                      Re: Print Quality
                      The developer material is probably done. Replace that and you should be good to go. Make sure the fuser is in good shape too. Also make sure the mag roller is clean before you add the new developer.
                      On a lighter note, while I have never been to Cuba, I have been led to believe the weather there is rather tropical. If that actually is the case, there is a small but real chance the supplies you are using for the machine were damaged by improper handling while in route to your location. I hope that's not the case, as the times I've seen that were unpleasant.
                      • Killeromantic
                        • Jul 2014
                        • 37
                        Re: Print Quality
                        Thanks Iowa Tech I think the problem of the loss of brightness in print leaving the impression in matte is the product that put a toner non OEM and so I read the toner that is not the manufacturer without any chemical ingredients like silicone gives gloss finished printing.
                        Perhaps you know that yellow dust Developer supports my Ricoh spc820 as some tell me that the Developer YELLOW B2309680.
                        PS: In Cuba the climate is tropical and humid well.
