MP9000 jam code 70
  • barber782
    • Aug 2011
    • 286
    MP9000 jam code 70
    Hi everyone,
    I have a MP9000 that constantly jams from all 7 trays with a j070, which i believe is the registration area.
    Sometimes i can get 2 or 3 out before jamming.
    When I remove the paper jam I have noticed 2 sheets doubled just before the registration rollers.
    Apart from cleaning it out or replacing the reg sensor is there anything else worth looking out for or adjusting?
  • allan
    RTFM!!
    • 5462
    Re: MP9000 jam code 70
    What happens if you remove all the paper except for the tray you are testing.
    Look at the common path on the conveyance between the trays and the registration.
    Whatever
      • 37641
      When is the last time, if ever, you preformed the following: 3.10.9 PAPER DUST TRAY, REGISTRATION SENSOR, DOUBLEFEED SENSOR CLEANING
      You may also need to replace the registration sensor if cleaning does not correct the problem.
