Savin 4045e Lost user name
  • h2ackski
    • Mar 2015
    • 11
    [Misc] Savin 4045e Lost user name
    what is the default user name have tried admin and supervisor combination but no luck
  • sognen
    • Jul 2014
    • 24
    Re: Savin 4045e Lost user name
    user: sysadmin pass: sysadmin tryed ?
    • h2ackski
      • Mar 2015
      • 11
      Yes, no luck
        • 37544
        Default administrator should be Name: admin with no password.
        If that does not work try Name: supervisor with no password. The only think supervisor can do is to change admin credentials.
        If both admin and supervisor passwords have been changed, there are numerous threads on how to change them back.
        • Robertgst
          • Jul 2015
          • 29
          I've seen a few of the defaults changed, i've seen :
          (try upper and lower case)
          User: Ricoh
          Pass: admin
          User: admin
          Pass: Ricoh
          User: Ricoh
          Pass: Business name
          • sandmanmac
            • 3983
            I believe on those older boxes the defaults were:
            U/N: administrator
            P/W: password
            ....But slims 'supervisor' suggestion should get you in
              • 37544
              U/N: administrator
              P/W: password
              Might be. There were also some boxes that used U/N admin with password as either Ricoh or Savin. We had a tech once who liked to set the password as the model of the box.
