best brand of remanufactured toner for Ricoh?
  • Killeromantic
    • Jul 2014
    • 37
    Hi, could someone tell me what is the best brand of remanufactured toner for Ricoh SPC820DN, I need to have a quality similar to OEMs.
  • logrady2331
    • Feb 2011
    • 301
    Re: best brand of remanufactured toner for Ricoh?
    If you want quality, buy the OEM. Aftermarket is less expensive for a reason. If you don't mind lighter, slightly grainy copies and premature developer, toner pump and fuser failure then Copylite or N/A Trading are probably as good as anything out there.
    • Killeromantic
      • Jul 2014
      • 37
      oky thanks. then keep buying the OEM for what I need is higher quality.
      • Killeromantic
        • Jul 2014
        • 37
        I forgot to ask you if you have used remanufactured toner and want to reuse the OEM have to change DRUM, I contaminate developers?
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          aftermarket toner SUCKS!!!!!!!! search the forums for toner pump problems, you'll see why.............
          Mystic Crystal Revelations
          • mrwho
            Major Asshole!
            • 4299
            People are right when saying OEM toner is best for Ricoh machines, as they can sometimes be quite picky on the toner they're fed.
            With that in mind, on older machines where OEM toner is hard to come by we've had good results using Katun toner - but only when OEM is not available and as a last resort.
            Mascan42
            Ibid
