If you use remanufactured toner and OEM toner you want to use the drum needs to be changed. My question is whether developers with remanufactured toner contaminated. Or simply changing the toner remanufactured and OEM putting solve the problem.
Change OEM remanufactured toner
Tags: None
Re: Change OEM remanufactured toner
And you wonder why you constantly have copy quality problems! -
Since you are in the Ricoh forum, there is difference between OEM and Genuine Ricoh. OEM merely means that the toner has the same ratio of components as Genuine Ricoh. It does not mean that the quality or consistancy of the components is the same. Particle size and other factors are not the same and can vary greatly, even within a single bottle toner.Comment
Well excuse my English is not good and maybe I knew not explain, what I know is that now I'm going to use genuine Ricoh toner does not affect the quality I have the same drum he had with non-genuine toner.Comment
possibly, ive had the old af1016 range destroy Development units because of how poor it is. Depends on what machine and how bad the toner was.Comment
