Control for mpc2050
+ More Options
Posts
  • en.
    • Jul 2014
    • 124
    Control for mpc2050
    Hi every one
    i have problem with mpc2050 its not responding and cannot coneting to network
    i do all this procudur :
    1-repleced the labtop
    2-repleced the driver
    3- replaced the hub swich&wire
    4-conected direct betwen the pc and device
    5-repleced the control board and hdd hard
    and its same problem
    by the way the divec was working proberly but and now it working by usp
    any one can help me ??
    • 37685
    Re: Control for mpc2050
    Check SP 5985-001. If it is set to 0, the on board NIC is turned off. Change it to 1.
    • fshead
      • 2378
      can you log on via WIM using the ip address?
      does printer show up when in service mode?
      • Brianneoe
        • May 2015
        • 322
        Print out a network page and check if control access are all zeros. If not, you will have to telnet into and clear out.
        • en.
          • Jul 2014
          • 124
          No i cant log via wim
          • en.
            • Jul 2014
            • 124
            Its 1
            • en.
              • Jul 2014
              • 124
              What you mean?? And wher i print this page
              • bob marley
                • Jan 2012
                • 1339
                also check SP 5985-002( On Board USB)if it is not working set to 1
                Live for yourself and you will live in vain. Live for others, and you will live again
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Check if IEEE802 authentication for ethernet is enabled in interface settings. If it is, it'll be locking the NIC out.
                  Hit it.
                  • barratec
                    • Jun 2008
                    • 162
                    Hi every one
                    Hi, try NVRAM of controller GW.
                    • Elmo
                      • Feb 2010
                      • 541
                      Print out config page check if any access ranges have been set
                      I Used To Live To Fix Things Now i Fix Things To Live
                      • mikadonovan
                        • May 2008
                        • 2925
                        If you mean USB, you probably didn't have to make all those hardware changes. Try making the changes suggested in this thread, especially enabling the USB port.
                        NEVER ASSUME ANYTHING
