Pro 8110s - Fiery error
  • fatfingers73
    • Feb 2013
    • 219
    [Error Code] Pro 8110s - Fiery error
    Afternoon all,
    Trying to set up an EB-32 controller, but I'm getting the attached message.
    Anyone know what could be causing this?
    Many thanks
  • Avalon
    RIkon Boy
    • Jun 2008
    • 53
    Re: Pro 8110s - Fiery error
    I've not seen that error before but I can see you're on version 1 Fiery software. If you've done a machine firmware update to a very recent version the Fiery will need updating to version 2.Listed below are the changeover levels.
    No
    Firmware
    Parts No
    Version
    1
    Package_ALL D1705506D
    2.01 or later
    Required firmware (Package_ALL):
    No
    Firmware
    Parts No
    Version
    1
    animation D1795767B
    1.05 or later
    2
    Engine D1795404N
    4.00:08 or later
    3
    NetworkDocBox D1795770D
    2.01 or later
    4
    System/Copy D1795760L
    2.01 or later
    5
    Web Support D1795765G
    2.01 or later
    6
    Web Uapl D1795766C
    2.01 or later
    7
    PDF D1795778C
    1.06 or later
    8
    Printer D7265701H
    2.00 or later
    9
    RPCS D7265703C
    3.13:31 or later
    10
    PCL D7265706D
    1.06 or later
    11
    Network Support D1795769E
    12.74 or later
    12
    OpePanel D1797290H
    2.01 or later
    13
    Browser D7265754E
    1.08:00 or later
    14
    Scanner D7265704C
    2.01 or later
    15
    RPDL D7265709B
    8.50 or later
    16
    Option IPDS D7265712A
    8.615 or later
    17
    Option R55 D7265705D
    6.32 or later
    18
    Option RTIFF D7265723B
    12.14.25 or later
    19
    MSIS D7265736B
    8.10.10 or later
    20
    BMLinkS Module D7195715B
    1.14.06 or later
    • fatfingers73
      • Feb 2013
      • 219
      Thanks for that. Haven't done that before, do I get it from the efi website?
      Cheers.
      No
      Firmware
      Parts No
      Version
      1
      2.01 or later
      No
      Firmware
      Parts No
      Version
      1
      animation D1795767B
      1.05 or later
      2
      Engine D1795404N
      4.00:08 or later
      3
      2.01 or later
      4
      2.01 or later
      5
      2.01 or later
      6
      Web Uapl D1795766C
      2.01 or later
      7
      PDF D1795778C
      1.06 or later
      8
      Printer D7265701H
      2.00 or later
      9
      RPCS D7265703C
      3.13:31 or later
      10
      PCL D7265706D
      1.06 or later
      11
      12.74 or later
      12
      OpePanel D1797290H
      2.01 or later
      13
      Browser D7265754E
      1.08:00 or later
      14
      Scanner D7265704C
      2.01 or later
      15
      RPDL D7265709B
      8.50 or later
      16
      8.615 or later
      17
      6.32 or later
      18
      12.14.25 or later
      19
      MSIS D7265736B
      8.10.10 or later
      20
      1.14.06 or later
        • 36805
        What OS version is on the fiery computer. I remember seeing something from either Ricoh or EFI saying not to update to Windows 10 directly on a Fiery Server currently running Windows 7 or Windows 8.1.
        EFI - Disable Windows 10
        • Avalon
          RIkon Boy
          • Jun 2008
          • 53
          Disk 1 and 4 are available from Ricoh site, disk 2 and 3 from EFI although they are rumoured to be the same as the E43A/83A. Alternatively order D7266613 and get the service disk kit.
          • fatfingers73
            • Feb 2013
            • 219
            Ok thanks. These are different to the 4 discs I have to do a fresh install then?
            • Vollegaaz
              • 73
              The message has nothing to do with the Windows versions in my opinion, but the communication between the fiery and the engine, i see the fiery version is 1.0, in that case the firmware version of the Pro 8110 is max 1.47.
              The recent firmware-versions of the Pro8110s (4.00 and up) are not compatible with the Fiery EB32 software, you'll have to upgrade the Fiery soft to version 2.0
              4 dvd package, plug and play, take's a while though.
              good luck and greetz!
              • fatfingers73
                • Feb 2013
                • 219
                Thanks for all the advice.
                Ricoh tech is going to burn me discs 1 and 4 and post them out to me. Hopefully that should do it.
                • Tonerbomb
                  AutoMajical Resolutionist
                  • Feb 2005
                  • 2589
                  You need all 4 disks to do this!!! The error you are getting is because the engine firmware is probably version 2.xx and the Fiery system is version 1. You need to do a fresh install of Fiery os version 2 with all 4 disks. This will take you about 1.5 hours.......
                  After completing the set up you need to install all the version 2 patches in correct order as well...........
                  Mystic Crystal Revelations
                  • fatfingers73
                    • Feb 2013
                    • 219
                    I already have 2 and 3. He said they're the windows 7 discs, and I can re-use them with the updated 1 and 4 discs he's sending me.
                    Does that not sound right then?
                    • Tonerbomb
                      • Feb 2005
                      • 2589
                      I would just go to the EFI site and download them to be sure nothing goes wrong, then you'll have a complete set of disks for system V2.
                      • Avalon
                        RIkon Boy
                        • Jun 2008
                        • 53
                        I can't see why EFI gave a link to download disk 2 and 3 if they are the same as the version 1 disks.
                        Just been out to the car to get my version 2 disks.Disk 2 and 3 are win764.1.1.1.15a part numbers 45122835 and 6 which is the same as the E43/83 and E43A/E83A. They are not the same as the E42/82 and E42B which is win764.1.1.1.11a/13a part numbers 45120171 and 2.I can't find my EB32 version 1 disks to check but I'm pretty certain they're not the right ones.
                        Short term it might be easier to downgrade the firmware, whilst you get the correct disks.
