IP-FAX Setup
  • techn
    • Aug 2025
    IP-FAX Setup
    Hello,
    I'm looking for info on setting up IP-FAX (using SIP) on a Ricoh Aficio MP 3351. Any special settings to get this to work? Is it T.38 compliant and does this need to be turned on anywhere?
    Ideally we'd like to just have the fax machine send to the SIP gateway but so far it doesn't seem to be working correctly; the channel opens up but the fax doesn't seem to complete.
