ricoh mpc2000,
  • tullio
    • Feb 2012
    • 268
    ricoh mpc2000,
    ricoh mpc2000 , print problem,new fuser.print b\n is ok.problem colour. urgent
  • tufbnme
    • 493
    Re: ricoh mpc2000,
    Even though you mentioned that the fuser is new, the problem appears to be a fusing issue.
    • Iowatech
      Not a service manager
      • 3930
      Re: ricoh mpc2000,
      I've seen something like that from non Ricoh toner and also from weird paper. Although in my case there was toner build up on the fusing belt and offset printing from that. I don't see any offset printing in the pictures, so I'm not sure.
      I guess you could try using a heavier paper setting and see if that would help.
      • matthewr88
        • Jul 2015
        • 28
        Re: ricoh mpc2000,
        can you resinstall old fuser to test, does look like fuser. check the image on the belt hows that look
        Can you fix it........we can fix anything its just how many parts do u wanna pay for
        • sandmanmac
          • 3983
          Re: ricoh mpc2000,
          As everyone else has suggested.....Looks like Fuser.
          Why haven't you stopped the image before the fuser to help isolate the problem??
            • 37553
            Re: ricoh mpc2000,
            Are you using a compatible toner or an after market toner? If you are, it may not have the same fusing characteristics as Genuine Ricoh.
            Print the non-default report and check that all fusing setting and motor speeds are at default. If not, set them to default.
            • ayeright
              • Feb 2011
              • 74
              Re: ricoh mpc2000,
              Good call. Also, is this standard, uncoated 80 gsm paper running as plain paper in the tray? These machines are very fussy when it comes to paper weight and type - you need to be sure that it's set correctly for the stock used. Remember that the UPPER weight limit for plain paper on this model is 81gsm and it will offset 90gsm on a run if it's set up as plain.
              Finally, any error codes, particularly on warm up? I've seen a failure of one side of the 'dual' fuser lamp where the machine can mostly make it to warm up but struggle to supply enough heat for a copy run. A quick check with your meter will rule this out.
              • tullio
                • Feb 2012
                • 268
                Re: ricoh mpc2000,
                thank you, I solved the problem of the oven.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Re: ricoh mpc2000,
                  How did you fix it?
                  When you come to the forums and ask for help the POLITE thing to do is post up how you resolved an issue.
                  A lot of techs gave advice and I'm sure they'd be happy to know if they helped.
                  • mikadonovan
                    • May 2008
                    • 2931
                    Re: ricoh mpc2000,
                    Let me guess, since you didn't say. Wrong print driver settings?
                    NEVER ASSUME ANYTHING
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      Re: ricoh mpc2000,
                      Originally posted by Oze
                      How did you fix it?
                      As Zootech put it in a previous thread "Hit-And-Run" ,an I chimed in with "Expert/End users" which I thought the acronym "HARE's" fit the purpose and facts rather appropriately...
                      Yes it's a tad disappointing when there is no resolve to the post.
