RICOH MPC 3000
  • bryant28282000
    • Jul 2012
    • 145
    RICOH MPC 3000
    Are you able to load firmware on a SD Card with Gigabytes? Will it work or do you have to use a card with MBs?
    Is it easy to load firmware on Ricoh mpc 3000. Does anyone have the firmware? THX
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: RICOH MPC 3000
    A 1 gig card properly formatted will work just fine.............
    Mystic Crystal Revelations
    • bryant28282000
      • Jul 2012
      • 145
      Re: RICOH MPC 3000
      Nothing is 1 GB. Best buy or staples start at 16GB. will that work?
      • MCC-support
        • Jul 2014
        • 38
        Re: RICOH MPC 3000
        Newer machines will work fine with a 16gb as long as they are formatted correctly.
        Older series may not play as nice with SD cards of that size. The ideal size is a 512mb but as stated, a 1gb works just as well.
        • Tonerbomb
          • Feb 2005
          • 2589
          Re: RICOH MPC 3000
          NO !!! ebay is your friend !!! lots of 1 gig cards can be found there...............
          • bryant28282000
            • Jul 2012
            • 145
            Re: RICOH MPC 3000
            thx!
            • Klydon
              • Mar 2009
              • 242
              Re: RICOH MPC 3000
              1 gig max on that series of machine.
              I believe someone posted something about if you use a larger card and partition it correctly, those will work as well.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3945
                Re: RICOH MPC 3000
                It just easier to go on eBay and order a bunch of the 1 go cards.
                Done and done. No format woes or BS.
                • Robertgst
                  • Jul 2015
                  • 29
                  Re: RICOH MPC 3000
                  I think the older machines will take 1gb max? But i know the newer ones can go up to 2gb sd card because that's what I use. They have them at walmart, i had to go get one because i didn't have any. They're in the camera section.
