Mpc 7501 fusing unit
  • khattab.al.masry
    • 212
    [Misc] Mpc 7501 fusing unit
    Does fusing unit of ricoh mpc7500 fits ricoh mpc7501?
    thanks in advance.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: Mpc 7501 fusing unit
    thanks in advance.
    No, I don't believe it will work, even though those fusers do look very similar. Some parts and connector wiring will almost certainly be different.
      • 37514
      Some but not all the parts are the same. Depending on what is wrong with the Mp C7501 fusing unit, you might be able to take parts from the MP C7500 fusing unit.
      • turbojetboy
        • Aug 2009
        • 279
        I have used both in either model. Only difference I can see is that you have to make sure the little loop wire on the upper rear connector assy matches the model type - justbswap one end of the loop into the correct position on its connector and away you go ( if you dont have it right you get the fuser not inserted message on the display). We rebuild the 7501 version and use it in all models.
        • khattab.al.masry
          • 212
          https://www.copytechnet.com/forums/r...81=#post402225
