Aficio MP C3300
  • JVC
    • Jun 2011
    • 151
    Aficio MP C3300
    Hello
    I mainly work on the Toshiba line but the boss just brought in the Richo and I am at a loss. I would appreciate any help.
    The copier is forced to duplex. There is no option for single sided coping on the screen. I have the book and have not been able to find the setting. Can anyone give me some direction.
    Thank you in advance
  • sandmanmac
    • 3981
    Re: Aficio MP C3300
    This is user manual stuff, so that's where you should be looking.
    You simply need to select/deselect the features you want as default, then program as 'default'.
    • khattab.al.masry
      • 212
      Re: Aficio MP C3300
      you can restore to factory default settings by open user tools / counter hard key
      then press (#)hard key and (copier features) on lcd panel key at the same time.
      • JVC
        • Jun 2011
        • 151
        Re: Aficio MP C3300
        Thank you for the replies.
        I have tried both and the single sided option is not available on the screen. Is there a place where single sided coping is disabled that I need to change?
        • Elmo
          • Feb 2010
          • 541
          Re: Aficio MP C3300
          The copier should be set to single sided as default
          and the double sided option select -able in screen
          to reset defaults goto user tools hold down the # key and touch copier/doc server box in screen
          this will then ask if you want to reset to defaults
          if the dsided options are not available on screen it may be the hdd is faulty or missing
          I Used To Live To Fix Things Now i Fix Things To Live
          • sandmanmac
            • 3981
            Re: Aficio MP C3300
            No "single sided option"! You simply deselect double-sided
            • tufbnme
              • 493
              Re: Aficio MP C3300
              Double sided is the default from the factory, just deselect it and set as default.
              • JVC
                • Jun 2011
                • 151
                Re: Aficio MP C3300
                Now I feel like a fool. On the Toshiba's there is both a selection for single to single each of the other options. I never thought to just turn off the double sided.
                • Iowatech
                  Not a service manager
                  • 3930
                  Re: Aficio MP C3300
                  Don't feel bad for too long, sometimes that happens to the best of us. And me, too.
