Ricoh Aficio 2035
  • tcypy1961
    • 773
    Ricoh Aficio 2035
    What would cause a shadow on the edge of the copies that are fed through the machine LEF (Lead End First)? The shadowing only happens when duplexing and only on the second side of the copies. If I duplex manually, the shadowing is not there. Thank you for any help given.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh Aficio 2035
    Bent scanner frame maybe? Give the front left corner a slight tug upwards.
    Hit it.
    • MCC-support
      • Jul 2014
      • 38
      When you say manually, do you mean manually feeding the single side output back into the tray or as in double siding using the platen glass?
      If the shadowing is happening when using the ADF and not the platen glass, clean all the ADF rollers and belt then check the ADF rego.
      If it is happening with both, there could be slipping in the duplex section. Clean all the guide rollers and check the clutches as they are prone to wearing out and slipping.
      • Iowatech
        Not a service manager
        • 3930
        For "LEF", are you sure you didn't mean "Long Edge First"?
        I may not be the sharpest copy in the shift tray, so I apologize if I am mistaken.
          • 37489
          Most Ricohs default to adding a 2mm offset to one side when duplexing. If the margin erase is less than 2mm, you get a shadow line. On the older models it is in User tools - Copier document server - Edit. On the new models it is in the Edit tab on the bottom of the Copy Function screen(as long as you are not in simplified screen). I always set it to 0 on all machines before delivery.
          • jfbar1
            • Oct 2008
            • 53
            ++ on that, had one of those tip over on the truck and had to do that to get the scanned image clear again.
            • TonerMunkeh
              Professional Moron
              • 3865
              Tip over? Fuck me. I bet that was a mess.
              Hit it.
              • SwanyG
                • Dec 2014
                • 55
                Dark band on the back of the copy LEF is usually bad developer.
