Lanier LD 445c/ aficio 4500c "add toner" when full .new toner pump clutch wont work?
  • davel
    • Oct 2011
    • 1107
    #16
    Re: Lanier LD 445c/ aficio 4500c "add toner" when full .new toner pump clutch wont wo
    Originally posted by tonerjockey
    yea, on the Savin CLP 28 which i think is a aficio ap3800 they would have a similar issue. you could hear the toner pump. it would call for toner. that was a box looking toner cartridge hopper on the upper right side with the toner tubes going down to the dev units. i would take stuff off to get to the pump and vacuum out the tubes. always worked. this machine, and i dont know if you can actually hear it vibrate, but the new tube was part of the toner pump assembly. there was some posts asking if this ones dev unit was turning. good question, but i mentioned in first post i thought that after doing an engine clear, the thing (pos) would pass copies in full color and they were good. well, black which its asking for started off nice and dark, now its light. the colors are misregistered which i will deal with in sim ? 21-11 A then D. i have to recheck that. and then go back into user modes and attempt the failed color reg adj. i'm really not dumb or inexperienced, at least i wasn't at one time if i am now. try driving around in the city and then deal with these things. i do appreciate your thoughts. one way or another, i hope to resolve this. one thought i should add. this machine was dropped on its side or back when the customer was moving it several years ago. when that happened, i was having a hard time resolving i think it was a fuser error. i finally found that the heavy power supply got cracked and i removed it and resoldered wires to repair the broken traces. now, i was wondering if there might be another bad connection, but i was thinking that if a voltage was missing, something else would stop. maybe that's a bad assumption. guess i should pull it and check. enough for one day. have a great Thursday, and thanks again you guys.
    Had one last week if you have toner drop out of hose at pump end try another pump, the one i fitted(new) was faulty, the clutch part had separated.
    • tonerjockey
      • Apr 2014
      • 567
      #17
      thats always the worst. you replace a part, unknowingly that its bad, and then start a needless chase of the tail. god i hope that didnt happen. but would at least resolve the problem. are the clutches interchangeable with the others? other than the toner contamination? i could try one of the others. the assembly came from a Ricoh authorized dealer.
      happy Friday, Jim
      • tonerjockey
        • Apr 2014
        • 567
        #18
        you just hit the nail on the head. i went back to retrieve the Hytech board that needs to go back. while there, i pulled the low voltage power supply i repaired a few years back looking for any additional cracks. all looked ok. i looked for the other board good ol Hytech said it could be. i had looked at the parts manual this am and they list a different part number for each pump. i suspect that is due to a different length rubber hose, and a slight different manifold tube bend. well, i pulled the black and magenta pumps again for the umtienth time. thought about blowing it out and swapping them. i looked really close and compared them and low and behold, the clutch has a collar on the inside side, and it wasnt held by the white retaining inner clip. and that ment that the gear was moving at lease a quarter inch on the shaft. i dont know how i missed that when i first installed it. but anyway, i pried that clutch collar back onto that bushing clip, reinstalled it and damn, it came right to ready in what seemed less than a minute. then i did the sim 2112 "C" and then "A" calibrations. did the user mode color registration adjustment and the copies were good. well, except for the magenta background. looks like it needs a drum. so, your the man of the day. and its Friday the 13th. so, thank you for causing me to think deep and get to the bottom of this. i wonder if the Ricoh dealer will compensate me for the crap i dealt with and all the money i spent? you can guess that answer.. thank you very much. have a great weekend, Jim
        • tonerjockey
          • Apr 2014
          • 567
          #19
          Originally posted by sandmanmac
          Exactly!
          I'm interested in why he's gone to the extent of replacing circuitry before even confirming that the Dev isn't the problem?
          We're still waiting on an answer to your question about whether he's tried another Dev unit??
          My money's on contaminated dev from CRAP toner.
          well, thank you "for waiting to see if "HE" has replaced the dev unit". i am not sure what you are referring too when you are talking in the third person persona. you were replying to my thread that i posted about an add toner message with new toner and a new toner pump. i guess i had an original post several weeks earlier that said that after doing an engine clear routine, "the copies looked fine". i see now that i guess i just rambled into where i had left off. sorry for that. i thought i had reiterated that after doing an engine clear. the copies were fine. so, i was getting disgruntled when the post kept asking me if the dev unit was turning and did i / HE change it yet. sorry. any knowledgeable tech would have known that if the copies were fine when the error was cleared, than that would obviously rule out the developer units. this thing got me frazzled. and as i replied earlier, it turns out that the root cause of the apparent mis diagnosis was due in part that when i found a bad black toner pump i called my Ricoh dealer. and they sent me a nice brand spanking new defective part. and being 85.00 plus shipping, i didnt want to purchase another on a whim.
          another now amusing thought. the post about "its totally billable" is it still? as i had billed them for the pump and labor. then was going to bill them for a exchange board. i have to pay for the shipping and restock on the board, but i see no way i can recoup those costs from the customer. i guess they did originally use generic toner. but the pump was bad, and i charged them to replace it. so i guess i keep the machine going for future service calls, but wont make a dime on this one. thanks Ricoh. i do appreciate all the input and thoughts from you all. have a great weekend, Jim
