MPC3003 Original is not detected on glass
  • hanspeter75
    • Mar 2010
    • 37
    [Misc] MPC3003 Original is not detected on glass
    As in the title. When copying always 2 x Start must be pressed in Auto Mod..Scannen from Glass also does not go. About ADF no problem.
    Controls: Sensors ADF and glass, Controller, Lens Block, SIO. Resetting the display setting ... not a success, an idea?
    Greeting
  • LNorris
    • Sep 2008
    • 645
    Re: MPC3003 Original is not detected on glass
    when u press copy the first time, what does the screen tell you?
      • 37556
      What size is the original?
      • hanspeter75
        • Mar 2010
        • 37
        Hi
        The Screen say "Orginal not detected" and it makes it with any format(A6-A3).
          • 37556
          Sounds lie your paper length sensors under the platen glass are dirty, defective or have loose connections.
          • hanspeter75
            • Mar 2010
            • 37
            Hi
            both replaced ... no success
            • ennadhe
              • Apr 2015
              • 7
              Do you hear any beep sound upon inserting the original?, maybe you have a problem with original detection sensor.
              • hanspeter75
                • Mar 2010
                • 37
                ADF liftsensor? do you mean the ADF open or close Sensor...looks good, the flag goes inside.
                  • 37556
                  When you close the ADF does the scanner move out and turn the lamp on? If it doesn't, the lift sensor is not working.
