MPC4501 lines color copies
  • omorales
    • Mar 2015
    • 86
    Hello friends your help with this problem, I have a Ricoh MPC 4501 when only draw back to reflex colored lines, while black is do ok.
    LD was changed scanner, lenses, exposure lamp, and everything was verified ok.
  • Iowatech
    Not a service manager
    • 3930
    Re: MPC4501 lines color copies
    Does that happen only when copying and scanning? It might not hurt to pay closer attention to the wiring to the exposure light source.
    I suppose it could be the SBU, but until you confirm that the exposure lamp is getting power throughout the entire scan I wouldn't worry about that.
    If that happened on the actual internal prints from the pictures you shared though, it is more likely that that is a problem with drum charge.
