MP C6501 - SP code 5104 - A3/DLT Double counter
  • aalex_bom
    • Jan 2008
    • 214
    How do MP c6501 counter is 2 when DLT/ 17x11 paper size, can not access 5104 code. print list SP mode data , 5104 is 1: yes.
    Anyone have any other ideas?
    • 37738
    Re: MP C6501 - SP code 5104 - A3/DLT Double counter
    You may have to access it through factory SP mode. When set at 2, YES except By-pass (Normal count for unknown size).
    • skynetto
      • Sep 2012
      • 257
      It is a SSP. Hold down # while pressing copy SP
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3941
        If I remember, once enabled it can't easily be disabled, so be careful where and when you decide to set it.
          • 37738
          That was 5045 Accounting Counter. Determined whether the counter counted printed pages or developments. When set for developments, a color page counted as 4 developments, 1 for each color, CMYK.
          • aalex_bom
            • Jan 2008
            • 214
            now I'm understand.
            Thanks you very much.
