MP C5502
  • CrapAimer
    • 296
    MP C5502
    Hi all
    went to a MP C5502 had a noise coming from fuser area, took it out cleaned and oiled it, put it back in fuser code kicked up, and machine has froze any ideas ??
    George
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: MP C5502
    Originally posted by CrapAimer
    Hi all
    George
    Was the code the SC544 code? If so, you'll need a reset fuse to reset the error. This thread has a lot of good info:
    http://www.copytechnet.com/forums/ri...html?highlight=
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: MP C5502
      The only noise I have from these fusers, is from a broken down fuser sleeve's oil pad. You will need to replace the complete sleeve unit, don't forget to swap the old stripper plate or take a new one.
        • 37491
        Re: MP C5502
        New sleeve units comer packed with a reset fuse. I haven't had to use one yet, so I am building a supply of fuses.
        • CrapAimer
          • 296
          Re: MP C5502
          Thanks for the replies, silly question when it throws up a fuser code does this stop the keyboard etc working as the machine i have nothing works. ??
