Problem updating MP161!!!!
  • Hadster
    • Aug 2011
    • 264
    So, I was updating the software when the power went out! Now of course I have a blank screen when the machine came back on. Is there any idea's on how to get this thing running again!
  • sandmanmac
    • 3979
    Re: Problem updating MP161!!!!
    Nothing at all?
    Never seen it myself (thankfully)
    The only suggestion I have would be to try treating it like an E32 or 40 error:
    Wait enough time that the machine 'should' have booted up, then try Clear modes,143, clear/stop (x5). Reboot
    • Hadster
      • Aug 2011
      • 264
      By blank I mean copier turns on, screen lights up with no print/words and machine does not cycle. Having no luck with SP mode or FP mode. Looks like I might have to replace the controller. Oh well sh*% happens! I will let you know....
      • Hadster
        • Aug 2011
        • 264
        Had to scrap original NVRAM's and use the ones with new (used)controller.MR's are different but customer ok with that. Now to go through all the settings! Yay! Not
        • tufbnme
          • 493
          It could have just been the op panel board that was blank. I did that once updating a 3245c. I shut the machine down before the fw was finished with the OP Panel. Replaced the PCB under the panel and updated the fw. This time I waited until done.
