aficio 1022
  • Gab
    • Aug 2015
    • 668
    aficio 1022
    When customer turns on machine in morning toner on the first 3 copies can swept , restcopies are ok. Tha same happens if customer doesn't use copier for 2 or 3 hours.
    Hot roller is compatible but i use this roller in other machines with no problems.Is there any any adjustment i have to do?
  • mikadonovan
    • May 2008
    • 2931
    Re: aficio 1022
    You might try turning on fuser idling.
    NEVER ASSUME ANYTHING
    • Polo-022
      • Sep 2007
      • 484
      Re: aficio 1022
      There is a ...pressure roller also!!!!
        • 37345
        Re: aficio 1022
        SP 1103 set to 1
        Check the green lever at the front end of the fusing unit. It should be in the up position. The down position is for envelopes and causes poor fusing on anything else.
        Considering that this model was introduced 14 years ago and require the use of a PCMCIA 1 memory card and special software to do firmware, it might be a better idea to replace the dinosaur.
        • copyaction
          • Oct 2007
          • 985
          Re: aficio 1022
          had the same symptom today on a 2022 and of course it was fusing fine by the time I got there, but I turned on fusing idling just in case (heat roller was just replaced).
          If they call back press roller will be next.
          • jfbar1
            • Oct 2008
            • 53
            Re: aficio 1022
            +++ on the pressure roller. After a while, it gets "soft" and while it may look OK, it will NOT fuse properly. You can increase the spring tension to see if it will help, but I wouldn't keep it tight as the plastic frame has a tendency to break.
            • rthonpm
              • Aug 2007
              • 2848
              Re: aficio 1022
              If the plastic frame around the heat tube has broken, replace the bearings with the ones from the 35/45 series that have the additional ring on them. Install the heat tube with that ring on the outer edge of the metal frame on the sides and that will keep it in place even with the frame damaged. Iy may take you a little time to get the heat tube installed the first few times, but it's a foolproof solution for a bad design. I even go as far to only use the 35/45 series bearings in the 1027-MP 3010 machines. I've still got a bunch of these out with low volume customers since these boxes just won't die. If all Ricoh boxes were as easy to keep up as this series and the older 1515 through MP 171 series boxes, life would be good.
                • 37345
                Re: aficio 1022
                I have noticed that with the newer models Ricoh has put metal tabs on both the side frames and top frame to keep the bearings from moving. I used to use heavy duty paper clips to McGiver tabs at the top to keep the bearings from moving.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Re: aficio 1022
                  Have had once the same problem:
                  1. never swap 3030 fusing unit with 2022 or 1027!!!
                  2. the cheapest papers even from IBM, xerox,... will end up in such a problem.
                  3. Always use the correct, Original hot roller for that model.
                  succes!
                  It is a dinousaurus, it is, but it's very easy to service (when you finally know the monster ).
