ricoh 3245c with sc670
  • axyun
    • Aug 2007
    • 1323
    Going to call this morning on 3245c with sc670 code. Will check connections etc but if anyone has info specific to this model series and this error code , your help is appreciated very much. Frank/ActionPhotocopy
  • axyun
    • Aug 2007
    • 1323
    Re: ricoh 3245c with sc670
    reseated boards on controller. no longer have sc670 code. Now there is sc440-02 code which i assume is yellow drum or dev drive problem. Frank
    • axyun
      • Aug 2007
      • 1323
      See that color drum brushless motor not turning. Is correct part number AX06-0289 for the Aficio 3245C ?Thank you
      • laitang
        • Nov 2012
        • 627
        Yes!
