I've found the easiest way on both is to use the 'Smart device monitor for Client' (Downloadable on the Ricoh website in the driver section).
Connecting up to it via USB, running that program, access the admin tab using the password 'Adminx74'. There are SP tabs that appear after that which will have the fuser code clear, diagnostics and calibration options.
To reset fuser SC hold down the Up & Down key for 10s then press Enter (or ok) for engine maintenance mode press Ok in the fuser SC reset then power off & on
