ricoh mp 4002
  • kopirmaster
    • Apr 2011
    • 70
    ricoh mp 4002
    i want to enter in sp mode i use c-yelow 107 c and machine beep e wont enter ,some ideas
    • 37480
    Re: ricoh mp 4002
    You have to hold the Clear key down for about 6 seconds, until the SP menu comes up.
    • kopirmaster
      • Apr 2011
      • 70
      Re: ricoh mp 4002
      i know how to enter but after 6 second machine beep and wont enter
      • ss12
        • Jul 2008
        • 289
        Re: ricoh mp 4002
        It won't let you in if a print job is processing
          • 37480
          Re: ricoh mp 4002
          Service access might be turned off by the administrator in user tools.
          • bob marley
            • Jan 2012
            • 1339
            Re: ricoh mp 4002
            could be something wrong with ur operation panel . try with another one
            Live for yourself and you will live in vain. Live for others, and you will live again
            • jfbar1
              • Oct 2008
              • 53
              Re: ricoh mp 4002
              Sometimes the "embedded" Java app will hang and it will take up to 10 minutes to allow service access. If you have the front door open when first turned on, as SOON as you get a "close door" msg. try to key in the reset, 107 clr. I've had to do that on occasion.
              • Captain Scott
                • Dec 2008
                • 166
                Re: ricoh mp 4002
                Go into your screen calibration menu to test all the hard key buttons 1993 or try accessing via factory mode. I had a dodgy 7 once
